Vin Numbers
Old Jul 8, 2003 | 03:14 PM
Dick123's Avatar
Default Vin Numbers
The VIN numbers on a blaster are located on the side of the frame. All the riding is wearing the numbers off. Is that the only place on the frame where those numbers are? What should I do?
Old Jul 8, 2003 | 03:27 PM
garyc660R's Avatar
Default Vin Numbers
I have never seen numbers wear off from riding,
Old Jul 8, 2003 | 04:28 PM
Dick123's Avatar
Default Vin Numbers
I sure cant read them. They were fine, but the frame started to rust from the weeds rubbing the frame.
Old Jul 8, 2003 | 04:39 PM
BlackandRedWarrior's Avatar
Air Cooled Rider
Future Govenator of Kalifornia!
Default Vin Numbers
I know on my warrior they seem to be in a bad location (almost on the underside of one of the bottom frame tubes), however they are somehow stamped into the frame. You may try to clean up the area real well and look at it. You may be able to take a sharpie type of marker or paint and "fill" in the VIN so you can actually read it if you need to.
It really seems to be about the WORST possible place you can put it.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
garyc660R's Avatar
Default Vin Numbers
Don't worry about it. There are numbers in at least 2 locations on the machine. If you can legally prove you purchased the quad, there is nothing too worry about anyway.
Old Jul 8, 2003 | 04:47 PM
Jeepman1991's Avatar
Default Vin Numbers
I have a '92 WR250 and I cant even find the vin number. I think its been grinded off.
It should be on the neck, nowhere to be found.
All I can find is an engine serial.
Old Jul 8, 2003 | 04:52 PM
garyc660R's Avatar
Default Vin Numbers
Did you check under the tank and the part of the frame that runs down too towards the peg?
Old Jul 8, 2003 | 05:09 PM
Dick123's Avatar
Default Vin Numbers
I didnt check under the tank. I will check there and see if I can clean that other one up. You are right, that is a bad place to put it. Also, how are you suppost to prove that you bought it without titles? I bought it used.
Old Jul 8, 2003 | 05:15 PM
garyc660R's Avatar
Default Vin Numbers
Some type of proof of purchase saying you payed for the bike.....and the previous owners signature should be enough.
Old Jul 8, 2003 | 05:32 PM
AlkyBurninX's Avatar
Default Vin Numbers
If you buy a new frame from yamaha, it doesn't have a vin number. It is just a part such as if you bought a wheel hub. Just in case you were wondering. Honda and all others do use a VIN though and you have to have your title changed.
