Blaster top end
Old Jul 11, 2003 | 12:11 AM
hoover7's Avatar
Default Blaster top end
I have very very little compression....the head and cylinder dont appear to be cracked so that leaves to mind the piston and rings. And my question is...can i get a big bore kit without porting and what not. Im short on money and both bikes are down. [img]i/expressions/face-icon-small-sad.gif[/img]
Old Jul 11, 2003 | 12:16 AM
Peltrax's Avatar
Yes you can get a big bore without porting but it wont really give you much more horsepower!
Old Jul 11, 2003 | 12:17 AM
hoover7's Avatar
i dont give a d@mn at this point...just want to fix it and sell it....
Ernie660R's Avatar
A big-bore kit will run you about $550, thats not including the machine work to install it. If I were you just get the next size up bore up piston (power piston from Vito's) and a advance degree key.
Everything including machine shop services should run you about $300, thats on the high side to me. Just to give you an idea.
Old Jul 11, 2003 | 12:18 AM
Peltrax's Avatar
Just get the cheapest piston you can then
Old Jul 11, 2003 | 01:11 AM
lilhags914's Avatar
i got a 98 blaster n i jus put a dyno jet kit on and its like its needs another gear on the top end get any suggestions
Old Jul 11, 2003 | 01:13 AM
blaster2088's Avatar
lilhags is my frend hes actually talkin bout ym blaster
Old Jul 11, 2003 | 01:10 PM
Peltrax's Avatar
Put a 14 t sprocket on the front
Old Jul 11, 2003 | 02:14 PM
how much would that sprocket cvost n y would jus a new sproket give me so much power
Old Jul 11, 2003 | 03:23 PM
dragracer789's Avatar
It wont make you have more power it will make you have more top speed. They cost from 6-15$
