Oil Ratio
Old Jul 11, 2003 | 02:32 PM
ruger's Avatar
Default Oil Ratio
How can you tell if you oil mixture is right for a banshee? Do you have to do a plug check or is there something else? I plan on running 32:1 but want to know if I can lean it out or if I have to richen the mixture. Thanks for any help.
Brad
Old Jul 11, 2003 | 08:12 PM
Banshified's Avatar
Default Oil Ratio
If you have any type of mods run it a 32:1, that's what all the pros do and I follow suit. If I even whisper the word lean around my banshee it starts shaking and pisses coolant all over itself. Just read the plugs every now and then to make sure. here is a good saying, a lean banshee is a fast banshee just not for long. The way i see it is, the oil you put in the fuel is all you have to lube the entire rotating assembly. Just my thought's
Cummins Driver
Sep 11, 2019 01:22 PM
Honski250r
Sep 26, 2015 09:40 PM
rockinkgin
Sep 25, 2015 01:52 PM
kdg723
Jul 25, 2015 01:20 PM
Fnqrider
May 31, 2015 08:29 AM
