raptor idle
Old Jul 13, 2003 | 04:27 PM
witti's Avatar
Default raptor idle
Myfriend has an 02 raptor with a yoshi pipe, pro flow K&N filter, no lid.
He is having trouble with the idle.
He turns the idle screw in until it idles at the right rpm, then rides it. When he revs it up the gas sticks at about 1/4 throttle for a couple of seconds then idles down.
If he turns the idle screw out until it doesnt idle then he goes for a ride it runs ok.
We checked and the cable is not sticking. He doesnt have to be riding it, it can be parked and you rev it up it revs fine and when it comes down it idles high for a while then idles down.
any ideas what to check?
Old Jul 13, 2003 | 06:11 PM
NotuRaptor2's Avatar
Default raptor idle
Check the choke cable where it goes into the carb to make sure it isn't all clogged up and rusty, etc. Sounds like the plunger might be sticking thus making it hard to really set the idle. You will have to remove the choke cable from the carb to look at it.
/NotuRaptor
Old Jul 13, 2003 | 09:41 PM
StockRappy's Avatar
Default raptor idle
my idle is messed up 2, but in a diff way, it sometimes stalls and putters, i have no clue wuts causing it
Firefighter400
Oct 8, 2022 06:38 PM
Aug 21, 2015 01:23 PM
black_thunder
Jul 22, 2015 06:01 PM
brad wheeler
Jul 13, 2015 11:19 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
