Wheelying???
Old Jul 15, 2003 | 03:59 PM
Warrior453's Avatar
Default Wheelying 101
i have a warrior with dominators in the back and a K&N airfilter other then that its stock. i weigh 120 lbs and 5'2'' and i cant get my front wheels up let alone wheely i sit as far back as i can and start in 1st and try poppen the clutch and my back tires just spinn i tried it in 2nd gear was coasten then i just gassed the $h!t out of it and all i did was go faster what am i doing wrong please help me.
Old Jul 15, 2003 | 04:14 PM
Jerrydlish's Avatar
Default Wheelying???
Try putting your knees on your seat, and your feet in your rear grab bar, and pull back on the handlebars. Try doing it that way until you gain a little more weigh, or go up a hill and at the top try.
Old Jul 15, 2003 | 04:18 PM
TheRaptorMan's Avatar
Try this...
Stand up and lean forward on the bike get your RPM's real low in first and drop your weight back on the seat hard and yank up on the handle bars, at the same time crank the gas. This may work.
Good luck! Just remember BE CAREFULL Being new with wheelies it will suck to get it up and then bring it right back over on you the first time!
Old Jul 15, 2003 | 04:29 PM
Jerrydlish's Avatar
The rear grab bar should save the wheeler from falling back on you....I used to wheelie and fall back on my grab bar just to goof around and the bike never came back on me....if you go slow you'll be alright....going fast is a different story.
Old Jul 15, 2003 | 04:56 PM
LilRaPtorboy660R's Avatar
alright i used to have to same problem cuz im just about the same size as u when i was a 300 ex alright if u come to a complete stop in 2nd rev up high enuff but too high cuz u'll go staight to the rack the dump the clutch and once its almost upright just feather the throttle and u'll be able to go forever once u learn to shift in a wheely...
Old Jul 15, 2003 | 05:33 PM
Yamaha660R's Avatar
put your knees on the seat, and your feet in the grab bar..if you can't wheelie like that, then your not supposed to wheelie
lol
[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jul 15, 2003 | 05:40 PM
JakalWarrior's Avatar
If you cant figure out how to wheelie on your own, you would probably hurt yourself if somone told you how. That or your machine is messed up. Slippin clutch or something.
Old Jul 15, 2003 | 05:45 PM
biggerisbetter's Avatar
Get RID of those Kenda dominators,and replace them with some Outsu's (factory 400ex tires) and you will be able to wheelie no problem.
Bigger.
Old Jul 15, 2003 | 08:46 PM
Warrior453's Avatar
BisB your right my dominators are warn and they suck really bad where can i find the outso but there 2ply
Old Jul 15, 2003 | 09:53 PM
Yamaha660R's Avatar
factory tires!?!?!
they are over priced, 2 ply, and they are crap. holeshots, razr's, razr 2's, anything are better then factory tires.
