wiesco power piston or vitos power piston?
Old Jul 18, 2003 | 04:23 PM
Vision's Avatar
Default wiesco power piston or vitos power piston?
whats the difference between these or are they more or less the same.
Old Jul 18, 2003 | 06:01 PM
Jennifer's Avatar
There is quite a bit of difference between the two structuraly. Both made by Wiseco though. This like anything you will hear good and bad. I have had them in my banshee since the beginning of the year and no problems so far. The skirts are shorter, the intake holes are higher up on the piston, the rings are definitely different on the Vitos compared to regualr Wiseco pro lites, the domes of the pistons look to be shaped differently also. My squish was fine with the pro lites but not with the vito's, I had to double up and run two base gaskets to get the correct squish Vito's recommends. I'm running the cast Vito's power pistons and so far they seem fine. Still doesnt beat a good set of pipes and a port job. We did several things all at once so the difference seemed minimal. Cast are about the same price as pro lites.
Ripinandtearin
1) Engine problems..
Dec 11, 2017 08:06 PM
robert301972robert
Aug 30, 2015 11:34 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
Ripinandtearin
Jul 19, 2015 08:38 PM
