What do you use to clean the oil filter element?
Old Jul 19, 2003 | 04:25 PM
DietCokeOfEvil's Avatar
Default What do you use to clean the oil filter element?
I'm a first year quad owner (warrior) and am about to change the oil, when I consulted the manual it mentioned cleaning the oil filter element instead of replacing it. The manual said to use solvent but after checking with the cycle/quad dealer and an auto parts store, no one carries an actual solvent. The guy at the auto parts store talked me into buying a spray can of brake cleaner saying it would work just fine since its designed not to leave any residue. What do you guys think? I should have asked here first but want to know peoples experiences before I try something that may have an adverse effect on my quad.
Old Jul 19, 2003 | 04:30 PM
dork's Avatar
brake clean works good. so does kerosene as in a parts washer. just spray from the inside out and blow it dry with air when you're done.
Old Jul 19, 2003 | 05:28 PM
2000IAWarrior's Avatar
brake and parts cleaner/ or choke cleaner. or gasoline. i use gas when i dont have brake cleaner ,just use air compressor to blow it out or you could ruin come bearing i think. o well hope it helps.
COFatboy
May 2, 2020 12:06 AM
cody500ho
14
Aug 14, 2015 05:03 PM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
Aitch
Jul 21, 2015 09:40 PM
