Raptor, Dash and Steering Stabilizer, Do they get in the way of each other???
I have a trailtech billet dash w/computer and I want to add a stabilizer. It seems that they all mount on top of the dogbone. I have seen some really $$$$$ one that are underneath.
Anyone tried this yet????
Thanks.
Thanks.
The denton mounts down low too, only the GPR and Scott's mountv on the top of the stem that i know of. i suggest the denton personally, its what i have. not to mention its a LOT cheaper than the GPR/Scoots, those both START @ 400$ and go up. the denton is 159$
Also GPR and Scott is adjustable on the fly while Denton and other that are mount inside the bike are not adjustable on the fly.
Also GPR is warranty for life. Does Denton is life warranty no they are not.
I have GPR and work great. Also I have the trail tech and it mount on the bar.
The Denton/Muscle can be adjusted on the fly if you install it like mine. Check my pics, I think I'm the only one that mounted one it this way. All I had to change were the bolts that hold the stabilizer to the frame, the included bolts were not long enough to mount to the thicker frame bar just under the left side of the gas tank. Mine has held up fine in the non-standard mounting position and works exactly the same as mounting it out the front.
09-30-2015 01:37 AM
