Extended swing-arm and longer chain???
Old Jul 20, 2003 | 08:03 PM
AlaskaYFM's Avatar
Default Extended swing-arm and longer chain???
Before I can put on my +2" Tucker Pro-Arm I'm going to need a new chain. So I figure this will be a good time to upgrade chain/sprockets and to also re-gear... Heres what I'll have in my engine: JE 11:1, Stage 1 Hotcam, CT Sonic pipe, Pro Flow K&N, and Edelbrock quicksilver carb kit. I'm still running 20" rear tires. I do mostly woods riding and some dunes.
I am thinking about maybe dropping a couple teeth off the rear sprocket and keeping the countershaft stock and perhaps also buying a second countershaft spocket a tooth lower. Still have '01 internal gears, too.
I've been looking at Sidewinder sprockets (tool steel) and their Gold O-ring chain.
Any thoughts on this would be great!!! [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 21, 2003 | 12:18 AM
AlaskaYFM's Avatar
no one has any experience with this chit? I figured a couple people have +2 swing-arms out there...
Old Jul 21, 2003 | 03:18 AM
raptorinmexico's Avatar
I installed a +2 Tucker swingarm as well and I went with the Sidewinder TI chain and sprocket. The chain is strong as hell and the sprockets still look new after two months of hard riding.
Old Jul 21, 2003 | 03:31 AM
DunePilot858's Avatar
If you are thinking about dropping 1 tooth off the front you need to add teeth to the rear to equal the same ratio. One off the output shaft = about three on the driven sprocket. On my Banshee I added 2 teeth on the rear but will be switching to 15 output shaft and stock on the rear. I didn't like shifting through the first 3 gears as fast as I was. I have a DID gold ATV chain that is holding up very well after a full season of riding. I do not recommend aluminum rear sprockets as they wear out very fast. I'm looking at a set of stainless steel sprockets for my next order.
Old Jul 21, 2003 | 07:40 AM
DaBeechMan's Avatar
If you take care of aluminum sprockets they will last. Sindwinder has some new tri-moly gears that are both light and strong as all hell. Same with their new chains.
Id drop 2 teeth off the back and leave the countershaft. You should go with a a countershaft sprocket 1 tooth higher, not lower
Old Jul 21, 2003 | 02:37 PM
FISHER1648's Avatar
I did the same as raptorinmexico only I have a +4 Tucker. Sidewinder is good stuff...
Old Jul 21, 2003 | 02:49 PM
AlaskaYFM's Avatar
I figured that dropping a couple teeth on the rear sprocket and keeping the countershaft stock would be good for duning while having an extra countershaft a tooth lower would make it better for the woods.
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
merryman
Sep 19, 2015 03:15 AM
