HOW Do i Tighten the suspension On my Warrior
OMG i realized my bakc suspension was soft today and i went over a jump( that i got over alot) nothing special just a like drop off over some water and it bottomed out I REALLY need to know how to tighten it...
Easy, Take out your airbox and you will see the top of the shock. There are 2 lock nuts that set the tension on the rear spring. It takes a special wrench to adjust these called a spanner wrench, any local motorcycle shop should be able to sell you one for about $15-20. On my girlfriends warrior I set the spring almost all the way tight to get it to where I thought it should feel. I also tightened up the front shocks to where there is only 1 click tighter. She only weighs about #120 and the factory settings where too soft even for her.
