Blaster pipe and silencer combos
Old Jul 23, 2003 | 06:18 PM
BALLZ's Avatar
Default Blaster pipe and silencer combos
I have a blaster and i mostly go mudding in it. I need as much power as i can get from 1st thru 3rd gear. What pipe and silencer would give me the most power in those gears. And I also need someway to increase my ground clearance. Can anyone shed some light on my situation.
Old Jul 23, 2003 | 11:26 PM
roosthrower's Avatar
the stock pipe would give you the most low end. Toomey is the way to go if you keep the revs up.
Old Jul 24, 2003 | 12:27 PM
MOJAVE02's Avatar
an exhaust will not do anything between just 1-3rd gears it works with the rpm range. most aftermarket pipes for the blaster will gain mostly mid to top end rpm, so really not to good for mudding.
Old Jul 24, 2003 | 02:19 PM
03Blaster's Avatar
I have an 03 blaster with a pro circiut pipe and silencer, with boyesen power reeds it has plenty of power
Old Jul 24, 2003 | 03:36 PM
JakeThreeight's Avatar
One of my friends has a blaster with the toomey on it and it has great low end, but i wouldnt know because i dont own one but the toomey seems promising.
Old Jul 24, 2003 | 03:40 PM
BLASTERDEVIL2's Avatar
get a toomey's and throw a 12 tooth front sprocket on if you need more bottom. if your only running 1st thru 3rd then lowering your gear ratio won't hit you. and then put some larger tires on for ground clearance. hope this helps.
Old Jul 24, 2003 | 03:43 PM
Peltrax's Avatar
Do what blasterdevil said....For more groundclearnace i dunno you already got 22 inch tires...try some skid plates that might help you glide over the mud easier...You picked the wrong quad for the mud!Set your preload high as you can ....Air up your tires a lot...
Old Jul 24, 2003 | 04:54 PM
BALLZ's Avatar
I know that I have to get a pipe for low end thats mostly what i need thats why i am asking what pipe i need. Oh and I know I have the wrong quad but hey you cant beat the deal i got on it. And can anyone suggest a tire that will fit on my 11-7 rims or a tire rim combo so i can increase the size of my tires.
Old Jul 24, 2003 | 04:58 PM
Ellison's Avatar
LRD, an FMF fatty has good lowend if thats all u want.
Old Jul 24, 2003 | 05:09 PM
you don't want to go much bigger on the tires. the blaster's seem to start boggin alot once you go any bigger.
