Pressure washing?
Old Jul 24, 2003 | 05:33 PM
WolverineMan15666's Avatar
Default Pressure washing?
I use a pressure too. It really gets the mud off. I did notice the last couple of times, that when I'm done and start it up it stalls when I give it a little throttle. It will sit and idle but stalls with just a little throttle. I have to let it idle for a while before I can get on it and go. I know something is getting wet but what is it? Anyone else have this problem?
Old Jul 24, 2003 | 07:05 PM
Guest
Guest
Posts: n/a
water in your airbox/intake element,
Patrick
Old Jul 24, 2003 | 11:21 PM
TTLBANSHEE's Avatar
I use a pressue washer and i havnt had a problem. Im always careful around my engine/air intake, electrical, and around my grease fittings. Im not sure if you could get water in the grease fittings but im guessing i can so i dont chance it.
Old Jul 25, 2003 | 12:24 AM
vampirerider's Avatar
Well, I spray off the mud, dirt, and weeds with a garden hose. Then I take a rag and wash anything I can touch. Takes about 1 to 2 hours to do a through job. But, the plus is you have had your hand on 90 percent + of your quad. If anything is going on, you should find it. For example I found the breather line off of my front differential once. I'd of never seen it otherwise.
Old Jul 25, 2003 | 12:29 AM
  #15
blasterdude13's Avatar
i use a pressure washer and hav no problems at all
Old Jul 25, 2003 | 12:32 AM
  #16
DragRaptor727's Avatar
i dont think id ever wash my quad if it took an hour...
Old Jul 25, 2003 | 01:11 AM
  #17
StockRappy's Avatar
my dad has a high power pressure washer even with a heater, the only thing it does is mess up ur decals, i suggest using a less powerful powerwasher, so far the raptor decals on the rear fenders are off and the big ones on the sides are starting to peel
Old Jul 25, 2003 | 01:38 AM
  #18
Hayseed's Avatar
Power washers have been around for at least 30 years, you'd think people would know what they are capable of by now.
Old Jul 25, 2003 | 01:46 AM
  #19
ALIENraptor's Avatar
Vampirerider, that is a good way to clean your ATV, i use my hands, pressure washers when used carelessly can rip through your gaskets and seal in your engines (not good!), maybe use the lowest setting, i feel hand washing it with warm water does a good job and everything is clean.
Old Jul 25, 2003 | 01:54 AM
  #20
Raptoryfn660r's Avatar
RIP Dear Friend
Yes to that.
I remember years ago before pressure washers were so popular that my dealer suggested for long term life of quad do not use pressure in the areas he pointed out.
I still buy fun stuff from this dealer[img]i/expressions/face-icon-small-smile.gif[/img]
ChetRacer[img]i/expressions/face-icon-small-cool.gif[/img]
