Need help installing kill switch on YFZ.....
Old Jul 29, 2003 | 12:20 AM
LokiDS650's Avatar
Default Need help installing kill switch on YFZ.....
Has anyone done this yet? If so, how did you do it? I have it grounded, but can't find where I should connect it. I tried different wires, but it doesn't work. Please help!
Old Jul 29, 2003 | 11:04 AM
raptorchick's Avatar
Anyone?
Old Jul 29, 2003 | 04:50 PM
ridnwarrior's Avatar
The other wire has to be hooked up to the positive wire going to the coil. There should only be 1 wire going there other than your spark plug wire.
Old Jul 29, 2003 | 04:59 PM
aussiequadrider's Avatar
I read that you hook up the long black wire to the white wire on the cdi.
This is for the pro design brand.
Good luck, Geoff.
Old Sep 3, 2003 | 01:48 AM
sandman10's Avatar
which white wire going into the cdi. the white one or the white w/ black on it? please help, i am having the same problem with hooking up my kill switch
Old Sep 3, 2003 | 06:21 AM
The solid white one.
Good luck Geoff.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Ripinandtearin
Dec 11, 2017 08:06 PM
frostphase
Aug 19, 2015 07:11 PM
Hatrackr
Aug 11, 2015 09:03 PM
Ripinandtearin
Jul 19, 2015 08:38 PM
