raptor baffle?
Old Jul 31, 2003 | 11:55 AM
BigScary's Avatar
Default raptor baffle?
you will destroy the baffle when you take it out..........take the bold out of the bottom........grab it with some vise grips...........twist it.........turn it and yank it.........
and a lill wd-40 wouldn't hurt!
IMO it sounds a lot better than stock..........but you will need to rejet!
Old Jul 31, 2003 | 12:23 PM
blinddog's Avatar
i took my baffle out.spray some wd-40 or other rust buster around the lip to get it between the pipe and baffle.then work itenough to get it started.vise grips do work.a screw driver and hammer tapping on it all the way around helps also.dont forget the set screw on the underneath side.your bike will have a little difference when you first tap on the throttle.it responds a little faster.the sound isnt too loud but it isnt as crsp as a aftermarket pipe.my $.02
Old Jul 31, 2003 | 02:49 PM
OjRaGe's Avatar
Do I have to worry about jetting it or any thing or is it safe to ride it all you want by just taking the baffle out?
Old Jul 31, 2003 | 03:12 PM
OjRaGe's Avatar
Also I'm located in Northern Minnesota if that helps any on if I have to jet my machine or not if I remove the baffle.
Old Jul 31, 2003 | 04:30 PM
  #15
Starky's Avatar
If all you do is take the baffle out you don't have to re-jet, but it depends on how it runs. After you take it out, if it hesitates when you stomp on the throtle you want to re-jet. If you're planning on doing some other mods like changing the air filter wait to re-jet when you are done.
Old Jul 31, 2003 | 11:34 PM
  #16
OjRaGe's Avatar
Well I got the baffle out of my machine no problem and it sounded good so I rode it around for an hour. I put the baffle back in later in the night mainly because its still under warrenty and the last thing I want to do is ruin my machine because it was running to lean.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
