P*SSED OFF!!!
Old 07-31-2003, 06:40 PM
RoostItUp's Avatar
Default P*SSED OFF!!!
Ya, I decided not to lower mine because of the problems I heard about it so I just ordered a 4" extended durablue axle and OMG it worked wonders! I haven't had one problem with tipping since I installed it! Just thought I'd throw in that idea.
Old 07-31-2003, 07:02 PM
Wicked686's Avatar
A longer swingarm makes a huge differance 2 - 3 over for trail 4 drags
Old 07-31-2003, 07:08 PM
sparksraptor03's Avatar
as long as you dont jump the lowering kit will be fine, i run a durablue kit for the front and a durablue strut for the back , the front hooks up to the top shock mount, and im in the process of making a custom front lowering kit for the bottom shock mount, you can get a durablue lowing kit from,www. magicracing.com
Old 07-31-2003, 07:40 PM
Yamaha660R's Avatar
I have a buddy of mine who know's how to drop the rear end...and I'll talk to him and get full details and a descriptive way to do it for you guys. I got my lowering kit off ebay. CFM Lower Kit is what I got. But there is a couple others on EBay that you can bid on, or just buy. They are on there a lot.
With the CFM kit, you get 2' wider, and 4' lower in the front. By dropping the bolt in the rear you drop 4'. All and all...the CFM kit was $55.
You can order the front kit from Durablue for around $70 off Rockymountainatv.com
But like I said...I'll return with the details about dropping the back of the Raptors.
  #15
Old 07-31-2003, 09:23 PM
FireFly's Avatar
just unbolt the rear shock linkage on the bottom of the shock, flip it over, and put it back on.
  #16
Old 07-31-2003, 09:45 PM
Yamaha660R's Avatar
That is how it's done. I knew it was something like that, but I wasn't sure.
That with the CMF Performance lowering kit, will drop me 4' in the front, 4' in the rear, and make me 2' wider in the front.
  #17
Old 07-31-2003, 11:09 PM
someone give me some more info on flippin the shock mount, or whatever, cuz im ready to ditch the durablue kit, p.m. with info
  #18
Old 08-01-2003, 12:18 AM
Yamaha660R's Avatar
I will let you know after I do mine, unless you get help before then.
  #19
Old 08-01-2003, 12:44 AM
Ernie660R's Avatar
The cheapest way to lower a Raptor is to install front and rear Banshee shocks on your Raptor. I think it will come down two inches.
  #20
Old 08-01-2003, 01:24 AM
Yamaha660R's Avatar
I don't know...$56 is pretty cheap to drop 4' in the front and rear.
