help changing sprokets on my blaster ?
Old Jul 31, 2003 | 11:21 PM
crispy's Avatar
Default help changing sprokets on my blaster ?
this may seem like a dumb theory but .... if i went up a tooth in the front sproket, and then went up like 2 or 3 teeth in the back sprocket, wouldn't that make it go faster yet keep the same acceleration because i changed the back sproket to make up for the front ? i wanna put a 14 tooth sproket on the front, but i don't want to loose any acceleration at all. so would that idea work? would i have to change the chain for this?
Old Jul 31, 2003 | 11:44 PM
roosthrower's Avatar
what would be the point of doing that. I would invest my money on engine mods or an after market grab bar.
Old Jul 31, 2003 | 11:49 PM
blindside350's Avatar
It only 20$ and its a good mod for gearing.... i dunno about the acceliration thing though
Old Jul 31, 2003 | 11:50 PM
crispy's Avatar
my point is that i would have faster top speed but not loose any accleration
Old Jul 31, 2003 | 11:57 PM
if you added a tooth to the front and dropped 2 or 3 in the rear you would have about the same gearing as you have right now. you won't accelerate faster or have a faster top speed.
Old Aug 1, 2003 | 10:17 PM
crispy's Avatar
what if i went UP in teeth on the back sproket, as well as the front. ?
Old Aug 3, 2003 | 02:34 AM
kaveman's Avatar
unless u do some engine modifications there is no way u can go faster without losing acceleration. I wish there was a way but.....dream on. If u go up teeth in the front and the back, they will cancel eachother out. Why don't u try out a 14 or 15 tooth in the front and leave the rear stock. If its not fast enough then u want to go down teeth in the rear maybe to 39 teeth. If ure acceleration is to slow with the 14 or 15 tooth in the front then try goin up 1 tooth in the rear to a 41. That will eliminate some of the top speed but not all of it. I heard some where that 1 tooth up in front is 7% increase in speed and one tooth up in rear is 3%. I dunno thats what i heard
Old Aug 4, 2003 | 06:05 PM
shlekter's Avatar
wow i think u r confused lol
Old Aug 4, 2003 | 06:10 PM
kaveman's Avatar
i meant one tooth down in the rear will add something like a 3% increase in speed
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
nastyblaster100
Sep 13, 2015 01:19 PM
bigbear350quad
Sep 11, 2015 12:40 PM
Jason Campbell
Sep 7, 2015 02:25 PM
Elkaholic
Sep 6, 2015 02:44 PM
