Banshee Bushings
Old May 25, 2000 | 02:47 PM
homeslice's Avatar
In the upper A Arm bushings in a 97 banshee how many are there total in jus tthe upper ones ???
my bottom ones are fine i just gotta get a number b4 i rip it apart and so i can have the parts.
Also on the kick start lever the kciker rattles and swings out. Is there a bushing or bearing in there that i can replace ??
Old May 26, 2000 | 02:36 PM
Veeshman's Avatar
Unsure of the Bushings for the A arms, but I know that there is not a whole lot you can do about the kicker. What usually happens is, either the ball in there wears out, or the shaft that the kicker in on wears out. The only way to fix the shaft is to weld it up and then machine it back down on a lathe. What my friend does is just puts a zip tie on the frame and hooks the kicker with the zip tie, it's a pain in the a--, but it is better than spending the money to fix or repair it, and it is not going to hurt anything or anybody. Just my .02 cents worth. I think that there are 2 bushings per side on the uppers. I have an ATV racing +2+1 front end and it uses Hiem joints on the upper pivots, plus I have the weld in A arm kit, since I have an 89' Banshee. Later
eric
Old May 28, 2000 | 05:48 PM
blaster18's Avatar
well if its like my blasters top a arms it takes 4
two on each side.
Customer Service #1
May 15, 2020 08:46 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Alex G.
Sep 19, 2015 06:34 PM
cdstang
Aug 31, 2015 07:52 AM
