warrior wont start?
Old Aug 9, 2003 | 10:28 PM
87warrior87's Avatar
Default warrior wont start?
my warrior wont start. it is an 87 and it won't pull start or the starter just clicks. can anyone help me out?
Old Aug 9, 2003 | 10:30 PM
OneWheelWheelie's Avatar
you just hear a click behind you under your rear fender it could be the cylenoid does the starter make lots of noise when you try and start it
Old Aug 9, 2003 | 10:37 PM
it makes one click everytime i try, that is it
Old Aug 9, 2003 | 10:39 PM
ya but where does the click come from everytime you press start does i click
Old Aug 9, 2003 | 10:40 PM
NLWarrior01's Avatar
Did you say it won't pull start ? My own Warrior doesn't have a pull starter .. hmm ... If it won't start under pull, then that rules out the battery being at fault, though it could be dead.
Have you checked for spark? If I've misunderstood about your "pull start", then it's probably the battery.
Need a bit more info on your bike.
Old Aug 9, 2003 | 11:31 PM
IT CLICKS UNDER THE left rear fender. i caan pull it but it just won't start. it won't fire, nuthin
Old Aug 9, 2003 | 11:35 PM
it is not getting any spark either, i wanna fix it myself because i am straped for cash
Old Aug 9, 2003 | 11:37 PM
KILLERCUDA's Avatar
Check the wire going to the cap. It pulls out i just foudn that out today checkin my plug try that.
Old Aug 9, 2003 | 11:46 PM
i pulled off the cap on plug and i did oone of those light testers and it is not getting any power to there
Old Aug 10, 2003 | 01:36 AM
ypman's Avatar
sounds like the cdi unit to me. I believe there is a way to test the resistance using a volt meter but I am not sure how.
