Please look at this!!!
Old Aug 11, 2003 | 12:06 PM
Warrior453's Avatar
Default Please look at this!!!
i just went to start my warrior and when i hit the little button to turn it over it made this ticking noise and that was it also next to the battery it was vibrating. do i have a dead battery??? i havent started it sense the first either.
Old Aug 11, 2003 | 12:13 PM
Raptorx44's Avatar
Have you tried charging it?
Old Aug 11, 2003 | 12:14 PM
Warrior453's Avatar
No how do u do that? can i hook it up to a Magnum 500 wid jumper cables
davis3340's Avatar
More than likely that is the case. Everything I own does that when its the battery although if you jump it and run it for awhile the battery could be alright. Im curious about the warriors do they not have a pullstart too?
Old Aug 11, 2003 | 12:15 PM
warrior007's Avatar
only the first and or second year had pull starts.
NLWarrior01's Avatar
Yeah .. try charging / boosting it first. If that doesn't work the perhaps it could be a stuck solenoid. If this is the case, give the solenoid a couple of light taps with a hammer or a wrench .. that works on cars .. should be the same for the Warrior .. have you tried crossing out the starting terminals with a screwdriver? up under the left rear fender you'll find the terminals ..
Old Aug 11, 2003 | 12:16 PM
Warrior453's Avatar
just electric no pull i wish it did tho
Old Aug 11, 2003 | 12:28 PM
Warrior453's Avatar
the lights work so is it the battery still?
Old Aug 11, 2003 | 12:32 PM
KILLERCUDA's Avatar
The battery can have enough juice to run lights but not crank over the engine. Just try boosting it.....
mxrookie's Avatar
Not enough juice to turn it over ! The lights will be able to come on with a little power left in the battery .
