Banshee
Old Aug 14, 2003 | 11:02 AM
Whitelightning74's Avatar
Default Banshee
Old Aug 14, 2003 | 11:33 AM
BigScary's Avatar
Default Banshee
sounds like it has good power!!!!
my buddies shee will only bring it up in 1st and second........and he is piped and jetted!
sounds like you have a beast!
congrats dude
Old Aug 14, 2003 | 11:39 AM
watz's Avatar
Default Banshee
A piped banshee will in 1-4 ported and polished should bring them up in all 6.....
Your going to need to find out who ported what stage port it is. You'll need new domes at a minimum to run pump gas. Check out www.thebansheezone.com probably the most comprehensive site about banshee's on line.
What did you pay forthat thing? Your probably running close to 90h.p. depending on the fuel.
If you raise it back up buy a +4 at a minimum and probably +6 swing arm or you'll spend more time on your backthan you will riding the rapped ape [img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 14, 2003 | 12:16 PM
Default Banshee
Old Aug 14, 2003 | 12:37 PM
watz's Avatar
Default Banshee
You got the greatest deal you might ever see in your life time. Stock 03 banshee should cost about what you paid... That banshee will STOMP every quad out, EVERYONE. No four stroker will touch you for lesst that 10g's, NONE! V-force reeds feed your cylynders those are about 200$, pipes are about 700$, port job usually around 400$, cool head and domes 200$, I am sure it has carbs around 300$, tires wheels, lowering kit, shocks, all in all you saved high dollar and that ***** hauls a$$!
I am jealous!
Old Aug 14, 2003 | 12:49 PM
BigScary's Avatar
Default Banshee
if the fram isn't bent or something you got a hell of a deal!
Old Aug 14, 2003 | 01:24 PM
MOJAVE02's Avatar
Default Banshee
it is setup for tt racing. it probably has the tt and flat track suspension components which you cant run on trails with so it will probably need to be converted unless you just plan to ride roads. also jetting will not affect what gas octane you can run. it must have race porting and below 20cc domes so the only thing you can do is change the domes if it has just mild porting, but if it has race porting you are stuck with running race gas unless you change the cylinders.
Old Aug 14, 2003 | 05:10 PM
Default Banshee
Old Aug 14, 2003 | 05:23 PM
Flynbryan's Avatar
Default Banshee
If you decide to get rid of those flat track tire let me know lightning. I'd be interested in them. [img]i/expressions/face-icon-small-smile.gif[/img] Oh and by the way you got the steal of a lifetime! You better go to your pastor and tell him you've sinned by theiving.
Bryan
Email me about the tires if you like:
www.flynbryan226@hotmail.com
Old Aug 14, 2003 | 05:47 PM
garyc660R's Avatar
Default Banshee
5th gear wheelies on a Banshee is VERY STRONG...most piped Shee's are lucky too get 2nd gear air. Excellent deal. Yep, check up on internals...you are probably locked into race fuel though.
