Warrior Bogs when I stand on it
Old Aug 14, 2003 | 04:32 PM
KILLERCUDA's Avatar
Default Warrior Bogs when I stand on it
Hey guys as you now Ive been doing some jetting IF you havnt noticed the threads hehe. Anyway I put the needle on the first clip went to a 170 main and put my stock piolet in. She still smells rich and when I stand on her in first there a lil bog then she throws me. If I catch it just right she'll pull em up in 1st and 2nd without trying. Do you guys think it could be my air screw? thats all I can think of Jay recommended a 168 main but i dunno because whenbrought up gradually she runs perfect no spits,sputters bogs ect. This thing has me stumped. I've tried it all. I'm hopefully getting a new carb before x mas but I want it to run good now. If I stood on it and it didnt bog it would probably throw me off and THAT's what I want hehe. Thanks
Old Aug 14, 2003 | 05:33 PM
KILLERCUDA's Avatar
It also like to try and die when its cold when yer lettin the clutch out you have to work it a bit. Thought this might give some clues too.
Old Aug 14, 2003 | 05:46 PM
JakalWarrior's Avatar
mine is a tad lean on top end with a 150, probably needs a 155 ....MAYBE 160 but I doubt it. My problem is it was way rich on the bottom end. I actually had to turn the air adjustment screw in farther than stock to get the bottom end to stop sputtering. I found out that the idle mixture screw affects alot more than just idle, it affects the mid range a whole lot too. When mine was an extra turn out the whole midrange was one big sputter, I tightened it up and the mid range got a TON better and now it only sputters a little bit when you hold the throttle about 1/8th open.
My mods are very similiar to yours.
Old Aug 14, 2003 | 05:51 PM
KILLERCUDA's Avatar
Hey Jakal alls u got is a 155 in yours!?!?! I got a 170. had a 165 in it when i opened the carb cause the guy I bought it from put a pipe on it. I guess I'll mess with that air screw thats really the only thing it can be. hmm its a mystery thanks Jakal
Old Aug 14, 2003 | 09:09 PM
I think your main is way too rich IMO. Drop a new plug in it, ride it WOT then just kill it. I bet the plug will be black and sooty.
Old Aug 14, 2003 | 09:34 PM
Crotts's Avatar
Try this Link, it has a very detailed section on carb tuning. It has a different carb setup than the warrior does, but it gives step by step directions for tuning.
Old Aug 14, 2003 | 11:49 PM
KILLERCUDA's Avatar
Thanks guys, Hey Jakal when I put my K&N on it leaned it WAY out and it had a 165 in it so I dont know what to do. One day i had a 175 in there right. plug was PERFECT. Next day take her for a spin fouls a plug leaves me 2 miles from home so I wind up pushin it home. That air screw sounds like my problem. Thanks for the website Crotts!
Old Aug 15, 2003 | 03:03 AM
Yeah, jetting is evil. I cant get mine right either. Mine just croaks if I floor it all at once from anything less than about 3000rpms. Who knows, it may just be our cam choice.
Old Aug 15, 2003 | 12:35 PM
KILLERCUDA's Avatar
heheh whats wrong with out big cams? lol I'm sure I'll get it out figured out someday. If I do I'll be sure and tell ya what I did if yers it still playing mind games with you.
Edit: Also Jakal have you been thinking about a different head pipe? I have and I'm thinking about the FMF Powerbomb or Hi Flo Since We've got a lumpy cam I'm sure it can handle a bigger head pipe.
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Sassinm1
Sep 30, 2015 04:23 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
