Brake swap
Old Aug 16, 2003 | 01:59 PM
Warrior8me's Avatar
Default Brake swap
Will the front brakes from a wolverine fit on a Warrior?
Old Aug 17, 2003 | 12:01 PM
raptorblasterracer's Avatar
Default Brake swap
idk but u can go to a junk yard and fine one and try to intall em!
Old Aug 18, 2003 | 02:18 PM
Warrior8me's Avatar
Default Brake swap
BTT
Old Aug 18, 2003 | 02:50 PM
95wolv's Avatar
Default Brake swap
Do you mean the caliper/rotor assembly, or just the brake pads? The pads will fit most all disc brake systems, Yamaha, Honda, etc. If you mean the assembly, the caliper might,but you would need the right mounting hardware to line up on the Warrior spindle.I'm not sure about the rest of it, being the Wolverine has a front drive shaft, and the rotor may mount different to allow for the CV shaft going through it.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
