I have a stupid question
Old Aug 17, 2003 | 01:11 AM
WolverineMan15666's Avatar
Default I have a stupid question
I have a 98 Wolverine. When I turn the air screw OUT am I making it run leaner or richer? It seems to get hot easy and starts bogging when after it gets hot. By the way, I have a K&N filter, stock jetting, and stock pipe. Its done this since I got it new. The temperature light never comes on either. If I let it cool down, it will run OK Any Ideas?
Old Aug 17, 2003 | 09:15 PM
DietCokeOfEvil's Avatar
The mixture screw only really affects idle performance. When you get over 50 percent throttle your mixture is done by your jetting and needle settings. I don't really see how it getting hot could be a product of the mixture. I'm pretty sure the wolverine does not have an oil cooler since its based off the warrior and it doesn't have one... you might look into an oil cooler for the heat problem.
Old Aug 17, 2003 | 09:44 PM
I was told that it might be getting hot like that if it was running lean. I turned the air screw all the way in and backed it out 2 full turns. It seems to run better. Yes the Wolverine has an oil cooler. The air screw must have been out 4 turns. I just wondered if turning it in makes it run leaner or richer.
Old Aug 17, 2003 | 09:49 PM
Crotts's Avatar
I know that on a warrior turning the screw in makes your bottom end richer. They are probably the same.
Old Aug 17, 2003 | 11:32 PM
RepTaR660r's Avatar
just the opostite on the raptor, in for lean, out for rich
EIF
Apr 20, 2017 07:15 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
