Best Raptor clutch kits?
That thing should be quite a sleeper with just the slip on. I love it
Air- Craycraft should have a 727 with override tranny on in dragstrip in the next 2 weeks. Nobody knows if it will make a pass or not. The motor is also going to have custom front end, custom dyna ignition, 39mm FCR's, custom intake, custom pistons, pins and special cam. The first pass should be interesting. It is also going to be sporting a large shot of NOS after it makes a few passes.
Wallstreet- I like the nology wire. The install is a breeze. You cut the existing wire and srew a collar over that and the nology wire srews into the other side. Then you heat shrink the supplied cover over that. Remove one allen head srew to ground it and you are done. I think it is worth the money. Looks good anyway
Adam- your quad looked good the other night at the track, now get it to hook up and get under 5.0 . I like that track and will be back. I hope to get to 5.2 or better on the 2001. The first night was dissapointing to say the least. Over jetted and a loose ground.
#16
#17
Mark, I found out it wasn't that I wasn't hooking up, it is my clutch. I made one pass, and ran a 5.5, and I was like, "that can't be right", so I went back, and did some more adjustments on my clutch and went and ran a 5.13 with no juice. So that was my problem, I think I can get below 5.0 with a new clutch. When is the next race at TSD?
#20
Air- this motor is not mine. The guy that it belongs to is doing every thing first rate. I would be afraid to even guess what the total price is going to be for all the mods, including the custom frame parts. We have no idea if the tranny is even going to work. It is going to be durability tested fast and hard under 5 seconds at a time. It might not even have a counterbalancer in it.[img]i/expressions/face-icon-small-wink.gif[/img] I do know the crank assembly should be back in Bobs hands by wensday of this week and hopefully it will be built this coming weekend and make its first passes the following weekend. The cam that this motor is going to run was installed in my raptor it break the cam in and not have to break it in on the dragster. It is a very interesting raptor build.
