Raptor Plug
Old Aug 19, 2003 | 04:50 PM
LOWBOWTIE's Avatar
Default Raptor Plug
Has anyone ever found a NGK any colder than a DPR9EA-9? If so where.
Old Aug 19, 2003 | 04:52 PM
HoundDog06's Avatar
Default Raptor Plug
We run DPR8EA-9. Is that hotter or colder than DPR9EA-9?
~HoundDog
Old Aug 19, 2003 | 05:24 PM
LOWBOWTIE's Avatar
Default Raptor Plug
That is hotter than the DPR9EA-9 . the larger the # where the 8 or 9 is is a colder plug.
Old Aug 19, 2003 | 06:24 PM
WallStreet's Avatar
Default Raptor Plug
I run a 9 and I am pretty sure that is the coldest they make.
Old Aug 19, 2003 | 06:27 PM
LOWBOWTIE's Avatar
Default Raptor Plug
Thanks Wallstreet
Old Aug 19, 2003 | 06:31 PM
BigScary's Avatar
Default Raptor Plug
how would you benefit from running a colder one?
Old Aug 19, 2003 | 06:35 PM
Ward660R's Avatar
Default Raptor Plug
less detonation
Old Aug 19, 2003 | 06:38 PM
LOWBOWTIE's Avatar
Default Raptor Plug
I'm just going by the diagrams for tuning on the NGK site and how to read the ground strap. And mine burns hot (white) all the way to where it welds on to the base ring. when the inside is black and the electrode is new looking. I'll probibly just jet up a little to compensate.
Old Aug 19, 2003 | 06:55 PM
FourStrokeFan's Avatar
Default Raptor Plug
Mine plug is the same way, without the black inside. I tried jetting up to 185/190 and got nowhere. Same white plug. At least now it runs right (I had to set the floats to 4mm above the mating surface). I'm giving up on reading plugs on the Raptor.
Old Aug 19, 2003 | 07:42 PM
LOWBOWTIE's Avatar
Default Raptor Plug
I also had to move my floats to about 4mm -5mm above the mating surface. Now my mains are alot leaner than when the floats were at the Rec. setting. They went from 190-195 down to 175-180 now. Just a tad on the lean side but not too bad at 4000ft. I need to move the needle up to the 4th clip now and adjust the Mix screws a little leaner and I think she be real close . But that still leaves the issue of a colder plug cause no matter how the jetting changes that part of the plug always stays the same. [img]i/expressions/face-icon-small-disgusted.gif[/img]
STLyamwar
Jul 25, 2020 04:44 AM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
