Warrior Engine Clanking?
Old Aug 21, 2003 | 11:02 AM
Farmerjoe's Avatar
Default Warrior Engine Clanking?
Hello all,
I am on my second warrior. My first was a '02, white, that i sold due to the divorce.....toys had to go!!!!!! But, I have now picked up another one. Its a '00, and in need of a lot of tlc. Its smoking heavily, which is an easy fix. But the bigger problem is a noise in the engine. I dont know if its normal or not. When you engage the starter, you hear a clank right before the engine turns over, and when you turn it off from running, you hear this clank too. I have removed the top end, and the cylinder, and if i put a wrench on the stator side of the engine, and turn it back and forth i can hear the clank. It sounds like its coming from the clutch side of the engine, but i am not sure. Has anybody seen this before?
Thanks,
Matt
Old Aug 21, 2003 | 01:02 PM
SpinCycle's Avatar
Flywheel may be loose!! Stop riding it and check it out now!! You will kill the crankshaft...
Old Aug 21, 2003 | 08:03 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
well when i start mine i sumtiems hear that calnk but not afterwards not sure what to do and yes tat clank came withthis quad and it's fine on mine but yours o man just totally disasemble the thign and re-build it
Old Aug 21, 2003 | 09:35 PM
SpinCycle's Avatar
yea, do what he says and just ride it until it dies. Then get on the forums and complain about what a crappy product yamaha makes and how your gonna sue them. I'm sure speedy has seen allot of key ways all messed up from a loose flywheel, it'll be just fine.. no worries about checking that out..
Old Aug 21, 2003 | 09:42 PM
Speedy2222's Avatar
if that happens i'll flip it down a hill and make the insurance pay for it....
Old Aug 21, 2003 | 09:46 PM
SpinCycle's Avatar
yea... the american way.
Old Aug 21, 2003 | 09:50 PM
Raptor58's Avatar
The one way starter bearings start to make clanking noises after a while. Some work like that for while without a problem they just make that noise
Old Aug 21, 2003 | 09:54 PM
Speedy2222's Avatar
my warrior only make s that clanking noise occaisonally VERYoccasionally
Old Aug 21, 2003 | 10:06 PM
JakalWarrior's Avatar
mine does it too, but only about once in every 8 or so times I kill it.
Old Aug 21, 2003 | 10:38 PM
shlekter's Avatar
mine always does that.....its the starter motor
