Minor airbox changes?
Old Aug 26, 2003 | 07:19 AM
Y2JRaptor660R's Avatar
Default Minor airbox changes?
I figured a few minor changes is a good start for more performance so i picked up prodesign air intake kit and crankcase breather filter. I also was also advised to re-jet up to 145-150 mains. I am removing the airbox lid for even more flow but i was told the pilot jets don't need replacing, is this right? Can the stock main jet(145) be used for the left carburator and i pick up a 150 jet and put in the right hand side carb? Thanks
Old Aug 26, 2003 | 10:21 AM
sixsixT's Avatar
Yes you can put the right main in the left carb. You might want to get a 155 main jet also.
Old Aug 27, 2003 | 04:57 AM
Do the stock pilots need replacing also? and the jet spes i was reccommened (145-150), seem about right?
Old Aug 27, 2003 | 06:39 AM
HappaRap's Avatar
Lazy Boy Rider!
I assume you are running stock pipe, correct? If so you can probably get away with stock pilot, put aftermarket pipe on then go up, if it's lean at idle.
Old Aug 28, 2003 | 05:30 AM
Yeah i am still running the stock pipe and header with only the bafle removed. I'll just have to try these specs out and do a plug check. thanks
Canamaniac!
Sep 15, 2015 06:19 PM
mbriggs
Sep 13, 2015 10:47 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Elkaholic
Sep 6, 2015 02:44 PM
ghost civic
Jul 20, 2015 12:36 PM
