opinions on 660Grizzly
Hello all
I'm new to this forum but have been reading for a while. I just got rid of my honda Rincon a purchased an 04 Grizzly. So Far I love this machine. I only have a hundred miles on it and I already like it better than my honda. Any info on this maching would be greatly appreciated.
Originally posted by: Andy Bassham
Hey dude, when I wrapped my pipe, I removed all the heat shielding. It is a royal bitch to get that crap back on there too. For the places the bolts screw in (which are mounted to the pipe itself), I cut a spare piece of the heat shield and stuck it on the pipe, then wrapped on around it with the main stuff to hold it in place. As long as you have a good tight wrap going, its not going to move any. The shield that covers where the pipe splits wasn't too bad, but those clamps were tough to get back on.
Now I have that HMF pipe on there that doesn't use the factory clamps, and its real easy. Almost makes me mad that I went to all that trouble before only to take it off a few months later. The way I did it was to start at the header at the engine and go around good an clamp it. Then wrap it to where it goes to one pipe and cut the wrap. Then start again on the other pipe and go till you overlap the original at the junction. Then just take that same strand as far back as you can go til you run out of stuff. I made it back past the carb on mine.
I swear, that crap was $40 for something real simple, but it did the trick, because I have never had one heat problem since (only had one before, but I wrapped it the next week). Even in the 100 degree weather we have been having, no problems. I also backed the bottom of the gas tank with that foam/reflective aluminum tape and thats all I have done. Never cut any holes in the side panels. It worked, cheap and effective.
Of course, we should have to do this at all with a new quad, but I would rather drop $50 in some cheap fix stuff than take a bath on a trade in for something else.
where did you get your foam reflective tape ?
Andy Bassham thanks for the info. I didn't quit understand everything that you described though, I guess I haven't looked at it that closely.
So you removed the metal heat shielding that is bolted to the exhaust pipe, then you just wrapped over wear the bolts went with the heat tape, or did you put the factory metal heat shield back on over the heat tape once you wrapped the pipe. Just need a little clarification to help with the visual.
Also, how do you like your new pipe? Is it very loud? I would almost rather just buy a new pipe since you have to remove the factory pipe to wrap it anyway, but I don't want to make my Grizzly any louder.
Thanks.
Thanks.
#16
Kraw- I got it at some hardware store. Nothing fancy, just that ducting stuff that is like 1/8" foam with think aluminum backing on one side and sticky on the other. Real cheap stuff, but it served the purpose. Cost like $3 or something for a roll of it. Dennis Kirk has small sheets of that stuff that actually looks like what yamaha puts under the fenders, but its like $12 for a 6"x10" sheet. I used that on the underside of the fender of my 99 AC right where the muffler is, because if you ever had a rider, they would burn their leg off on the plastic. It would be real expensive to get enough of it to do the tank bottom, but it would be better than what I used. Would look better too (if you could actually see it)
#17
Area51- Yes, removed the heat shield, wrapped around the place the bolts went, and put the shield back on. Didn't have to remove the pipe when I had the stock pipe, just unfastened the clamps (right by the carb) and wrapped under them. Its a pain to get them back on, because the diameter is of course bigger after its wrapped. I ran out of stuff right after where the cover for the pipe goes, just a little ways past the carb. Highlifter doesn't give you many clamps though.
The pipe is very loud. Will rattle your skull, and really hard on whoever is behind you. I don't mind it, but I'm sure a lot of people will. I guarantee you will turn heads when you ride past a crowd though. Its a lot louder than stock, and I mean a lot. I won't shoot you wrong on that part, cause some people try to say its not all that loud. Buddy, its loud.
#18
I took a couple pictures of the thing, but its not any good really. Can't see much due to the the heat shield in the way, and I wasn't taking that thing off just to get a picture of it. They are in my yahoo photos in the sway bar folder. Also, my back heat shield is different, because the HMF has a different bend, so I cut about 6 inches off of the stock shield and bent it to fit. A little ugly, but it works.
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
