Upon further inspection..
Man my one way is destroyed after rubbing my finger on the ac magneto or flywheel theres metal all over it, also do some of the idler gears held on by the case? and to get the starter off do i have to remove the C clip thing? And my cam chain dropped can i get it out easily?
My one-way was the same. What about the idlers? No, the starter can come out of the case with the pinion on, make sure to grease up the o-ring for it when you are putting it togehter.
Cam chain dropped where?
Cam chain dropped straight down, i try to get it out, but its binded, the motor turned over a bit[img]i/expressions/face-icon-small-blush.gif[/img] How do i get the starter off? And what about the stator wires?
The stator wires have a plug up the frame a little bit, just under the plastic toward the front of the seat but I usually just turn the cover with the stator in it out of the way and rest it on the heelguard.
If you have the one-way or flywheel out the cam chain is right there but you will need access to the top and bottom to do anything with it. I assume you have the cover off?? But Do you have the cam out aswell??
I wouldnt do it much but you can use a socket to turn the crank backwards a little to free the chain, just hope you didnt damage it when you kinked it.
i dont know what happened just it wont come out, the head is off to repair a stud but i like to complecate things, Hiram from this forum is helping me out, what a good guy[img]i/expressions/face-icon-small-smile.gif[/img]
hmm I am thinking about replacing the oneway, do i need an impact wrench, i dont have a compressor, but I can get a breaker bar
