yamaha blaster
Old Aug 29, 2003 | 12:36 AM
rxfx's Avatar
Default yamaha blaster
looked at the spark plug in my blaster and it was wet and covered in wut looks like oil. does that have anything to do with why it wont start? it will run, but only when the throttle is pinned and isnt reving high at all for only a short time. then it'll take another five min or so to make it start again. i think its the valve float. wut u guys think?
Old Aug 29, 2003 | 03:48 AM
raptor8's Avatar
sounds like you are getting way too much fuel. go after the carb.
Old Aug 29, 2003 | 04:03 AM
Crotts's Avatar
If your floats were stuck your carb would dump fuel out the overflow. raptor8 is right sounds like you are way to rich and isn't starting because it is fouling the plug
Old Aug 29, 2003 | 04:28 AM
raptor8's Avatar
check out the air filter too. it sounds way too rich to us.
Old Aug 29, 2003 | 12:31 PM
rxfx's Avatar
so what do i have to fix on the carb? im not familiar with atv's...
Old Aug 29, 2003 | 01:27 PM
Peltrax's Avatar
you need to fix the "jetting',if you arent sure about it i would take it to the dealer,tell them you need to have it "jetted" corrrectly
Old Aug 29, 2003 | 01:32 PM
BLASTERDEVIL2's Avatar
you might a flooded it real bad. change the plug and have someone pull you down the road and try to jump start it to clean it out. what do you do to it before it started doing this?
Old Aug 30, 2003 | 01:08 AM
rxfx's Avatar
we were doin jumps and then he took it down this road that is real rocky and ish, once he got to the bottom it bogged out.
Old Aug 30, 2003 | 01:23 AM
Crotts's Avatar
put a new plug in it and see if it does it again. chances are it just flooded
Old Aug 30, 2003 | 02:15 AM
rxfx's Avatar
so, if its flooded, then wat?
