any raptor 300' drag times?
Old Sep 8, 2003 | 10:48 PM
  #21
DollarBillz's Avatar
Default any raptor 300' drag times?
well what did you run?
Old Sep 8, 2003 | 11:05 PM
  #22
SLIM660's Avatar
Not anything worth posting yet!!! I'm still own the stock length swingarm with no wheely bar. I put the front end down 2 inches from the ground of hoping to keep it down but it was impossible to keep it on the ground. I can deal with it on the dirt but the asphalt was a different story. I've got a 3 inch over stock swingarm that I can get but after trying it this past Sunday I plan on going to probably 6 inches. If and when I get a swingarm and a good run all the way through the 1/8th I will post the times good or bad. Slim
Old Sep 9, 2003 | 04:28 PM
  #23
bad350twin's Avatar
what would be a good 1/8 mile asphalt time for a 686 on gas and stock tires?
Old Sep 9, 2003 | 07:28 PM
  #24
14mins's Avatar
bad350- 8.2 to 8.5
Old Sep 9, 2003 | 09:57 PM
  #25
SLIM660's Avatar
Well I did do at least those those times even with it in the air, up in the air in first three gears, on and off the throttle and missed a gear while trying not to loose it. It was a wild ride. Got to have that thing extended!!! Funds are low; real low since the wife left A YEAR AGO. ALL DONATIONS WELCOME. Slim
Old Sep 9, 2003 | 10:40 PM
  #26
CountryJoeGlass's Avatar
themoose your right about the down hill slant @ the texas sand drags but a 30' drop from start to finish is incorrect. thats saying you could build a 2 1/2 - 3 story building @ the 300' finish line and it would be level from the starting line to the top on the building. 30' sounds like a soap box darby race track. it falls but not like that. when they wet down the track the water isn't running down the track like a stream. don't get me wrong it is sloped pretty good, but. enuff of my over explaining.
later!
Joe
Old Sep 9, 2003 | 10:55 PM
  #27
RaptorRidrTX's Avatar
I've seen ppl run the same time at Texas Sand drags as they did at Atoka, it's not near as downhill as it appears to be. I heard the new track at Little Sahara has a nice upslope to it though
Old Sep 10, 2003 | 02:11 AM
  #28
bad350twin's Avatar
that sounds about right ... i was just seeing how i stand against everyone else!
Old Sep 10, 2003 | 11:48 AM
  #29
UBETRUN's Avatar
Slim - How did you get your wife to leave? I need help, none of my ideas aren't working!
black_thunder
Jul 12, 2015 11:04 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
