GRIZ FAN NOT WORKING
Old Sep 1, 2003 | 09:58 PM
RaptorRy's Avatar
Default GRIZ FAN NOT WORKING
had a little troble witha stump that took off a small coolant line on water pump( i think) and once I fixed it the fan doesn't work and my dam coolant temp light is coming on any help would be great
I ran direct power to the fan and it still works so my hands are in the air
Old Sep 2, 2003 | 08:28 PM
acetrane's Avatar
Sounds like you have air trapped in the engine block. had that problem with a buddies polaris after we rebuilt the engine. You have to bleed the air out or the fluid will not circulate.
Old Sep 2, 2003 | 11:36 PM
Vakero's Avatar
leave the radiator cap off ovre night and it will bleed itself. Post back if you still have a problem and I will look at the wiring in the book.
Old Sep 3, 2003 | 01:25 PM
RaptorRy's Avatar
I did have a air lock in the cooling system took off pressure cap and let run for a while to circlate coolant added a little and now every things a go fan works and temp light is off thanks for all the help now i should be able to get in the woods for bow opener with out having to shell out repair bill for the griz Thanks Again
hugemoth
Jul 20, 2020 03:28 AM
toonces
Oct 16, 2019 12:11 PM
rcappie4
Jul 18, 2015 07:51 AM
timster911
Jul 13, 2015 01:57 PM
bikedad3
Jul 2, 2015 02:15 AM
