Raptor Oil Changes/Oil tank Pipe
Old Sep 5, 2003 | 11:23 AM
BUDXXX's Avatar
Default Raptor Oil Changes/Oil tank Pipe
When changing oil on Raptor, it seems a lot easier and cleaner to disconnect the oil pipe from the tank to the engine, right at the engine, in order to drain the tanks oil. The way the book recommend is to drain the tank, what a sloppy mess unless you fab a little funnel out of a oil bottle....
Anybody had any bad experiences to report about disconnecting the pipe at the engine..instead.....?
Old Sep 5, 2003 | 12:00 PM
warrior007's Avatar
I was looking into getting a new oil line made up with quick disconnects but nothing has materialized yet or putting the coupler right on the tank. if there were only 25 hours in the day
Old Sep 5, 2003 | 12:04 PM
BUDXXX's Avatar
Mine is an '03 LE, and the oil pipe to the engine has a compression fitting right at the engine. Seems perfect for disconnecting and reconnecting....
Is that different than yours.?
STLyamwar
Jul 25, 2020 04:44 AM
Kaleb_00
Jun 1, 2016 09:15 AM
Jason Poulin
Sep 20, 2015 02:49 AM
Aug 25, 2015 11:16 PM
Aug 21, 2015 01:23 PM
