HOw do i jet my raptor?
what jet sizes clip position? i need to know everything im running a yoshi comp with out the spark arrestor i was just wondering because im about to tear into it. i have a pro flow with a K&N
also what do i have to take off "plastic" like the gas tank ect... to get to the carb. And anything else i need to know before let me know
Take the front fender off, then the gas tank and the rubber over the carbs. Take the carbs off from the boots. And flip the carbs over. Before you start I would go down to Lowe's or Home Depot and get some 4mm by .7 bolts. To replace the crappy screws. Remove the main jet and pilot jet and replace. I spray the bowl with carb cleaner to make sure its clean the replace the bowls. Flip the carbs back over and remove the black cover. Take the spring out and remove the guts and change the clip position to the 3rd clip. Try a search on clip positon to hear it better. I "think" you should run 155, 160 and 25 pilots. Hope this helps.
i got her jetted 146/148 3rd clip position with the airbox lid it runs great throttle repsonse is a lot better but when i wheelie it wants to cut out. only once when i was riding it, it shot out a flame so im thinking its still running a little rich. so im going to take the lid off tomorrow and see if it cleans up on wheelies
any advice what might be happening???????
Alex Rodak
09-13-2015 12:30 AM
Alex Rodak
09-12-2015 09:39 AM
Alex Rodak
09-11-2015 11:42 PM
