Blaster - Tri Z rear end swap
Old Jun 4, 2000 | 07:37 PM
Kiwi-Craig's Avatar
Ok blaster experts, can you bolt in a Tri Z rear axle carrier onto the blaster swingarm and there fore get a wider rear end, disk brake setup and reuse your rims (they have the same bolt pattern PCD)
has anyone tried the entire Tri Z rear end in the blaster chasis.
Old Jun 4, 2000 | 10:03 PM
Ryan88Blaster's Avatar
Go to www.blastercentral.com and go to the bbs, then post a question to flyin'ryan I think he know's a little about this.
Old Jun 6, 2000 | 10:53 PM
EdSmith's Avatar
I've seen it done. Someone bolted on the entire rear end. The had to fabricate a new upper shock mount and a mount for the shock linkage (I think), but other than that it appeared like a fairly easy mod. A Warrior shock was used. The hub bolt pattern is the same, so you existing wheels can be used.
Old Jun 7, 2000 | 12:00 AM
94DGblaster's Avatar
what is the whole point of this?
i've never seen a Tri-z...longer swing arm?
Old Jun 7, 2000 | 12:49 AM
Loofer's Avatar
Im guessing..you get the rear hydraulic disc brake
Old Jun 7, 2000 | 03:40 AM
Kiwi-Craig's Avatar
why bother, ok, thoughts are:
1) 4" wider rear axle, no need for spacers or expensive aftermarket, hub pattern matches a blasters wheels.
2) hydraulic dis brake all set up to go.
3)longer swingarm by at least 2" but still seeking confirmation.
4) Linkage rear shock with i think on the tri-z adjaustable damping
5) Tri-z parts should be dirt cheap compared to Warrior or Banshee or aftermarket
6) It would make for an interesting diy project
If anyone has a few tri z rearend photo's that would be great, save me a 100 mile trip to check out one of my buddies rides.......
Kiwi Craig
Old Jun 7, 2000 | 12:00 PM
Now i am going to have to look into this!
I really need better brakes.
Hmm...now to find a Tri-Z rear end. Should be fun.
Old Jun 7, 2000 | 03:35 PM
EdSmith's Avatar
Exactly. The Tri-Z shock is adjustable and has a reservoir. It has suspension linkage, so you should get a better rear suspension. Good luck. I forgot to take pics when I saw one, sorry about that.
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
austinwhitton
Aug 11, 2015 06:21 PM
315blaster
Aug 8, 2015 08:13 PM
