L&A installed...wow
Old Sep 27, 2003 | 11:53 PM
Yamaha4eva's Avatar
Default L&A installed...wow
this is such an improvement, it even sounds better! the only hard part putting it together was the 110 pounds of torque that holds the fylwheel...we had to put like a 50 pound wrench on it to turn it, we had it in gear and i was standing on the break and the wheels were still turning....LOL
Old Sep 28, 2003 | 12:45 AM
Yamaha4eva's Avatar
didnt touch the carbs, it just starts faster, doesnt make that annoying click after it stops, when it starts it doesnt sound like the engine is shredding itself up, alot stronger i even dropped it and it didnt even scratch
Old Sep 28, 2003 | 02:54 PM
BlackWidow's Avatar
Gary... He's talking about the L&A Designs replacement one way starter clutch. Check it out on raptortranny.com. Mine works great too. No "ker chunk, ker chunk" noises anymore and the price is comparable to replacing the stock peices that break just as fast as the first ones did! Plus it's a little lighter so it gets the flywheel weight down.
A++ for a "Best Buy"!!
Old Sep 28, 2003 | 09:02 PM
sandRappy's Avatar
I have a few questions about the one way I hope you guys can help me with, because I am going to need to do this very soon.
I was just wondering can this be installed with just pulling the side cover off, or will you have to split the cases? Is it very difficult to install, and are there any special tools you need to do the job? Also, if the one way bearing goes out how do you know, and is there anything it will hurt? I guess what I want to know is should you change it over to the LA design one way before something bad happpens or can you just wait for the stock one to go bad before you repalce it?
Old Sep 28, 2003 | 09:19 PM
wshrdskin's Avatar
Just take the side cover off. Special tools? An impact wrench would be nice, electric or air, 1/2" drive. You'll need a flywheel puller. If the old oneway goes out you'll know by the grinding/clunking sounds you here when you try and start it. The spring around the one way gives way and the rollers become loose. If you wait to long the gear the one way rides on will need to be replaced. The most difficult part would be getting the nut loose and pulling the rotor off. The air or electric impact will help with the nut.
Old Sep 28, 2003 | 11:39 PM
Mr45auto's Avatar
It's easy to install, check raptortranny.com for instructions. Ive got one on my Rappy as shown in my gallery pics here you can see how it sits in there and the flywheel puller you need.
Old Sep 28, 2003 | 11:48 PM
wshrdskin's Avatar
45auto,
It's hard to see but does your dyno say 90hp? 686, fcr's, stage 2 cam? Wouldn't that be sweet. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 29, 2003 | 01:09 AM
Mr45auto's Avatar
Actually that's the torque curve you see, it's numbers are on the right side. 47ft lbs ish, the HP was an even 58. 90 would have been great tho! LRD said it was pretty high for a 686 on their dyno.
Old Sep 29, 2003 | 08:37 AM
Yamaha4eva's Avatar
your gonna need 2 torque wrenchs...one for 10 i think and the other is 110
Old Sep 29, 2003 | 12:29 PM
BlackWidow's Avatar
I think 4eva is right, 10 ft lbs on the allen bolts that hold the one-way and the magnet and 110 to torque the crank nut. Make for SURE you get the crank nut tight enough, I didn't the first time and it was starting to work a little bit in the month or so that it was back together before I put the L&A in.
Should be a relatively easy job for most anyone. I think the only drawback to waiting until the original one way goes out is the metal shavings that end up in the oil. Fortunately I think most of them get stuck to the stator magnet and don't go much anywhere!
The only other suggestion is that if the gear that the one way rides on is torn up at all, get a new one! I'm not talking about the gear teeth themselves, but the surface that the one way rides on. Might as well replace it while you're there and I found a heck of a deal through Ripper Racing.
Ripper Racing
I think that if you added up the cost for new factory parts (one way, gear and gaskets) you'd be at the price that Ripper has the whole package for. Might as well upgrade!!!
