Blaster 200 engine swap
Old Sep 30, 2003 | 06:42 PM
Speeedracer's Avatar
Default Blaster 200 engine swap
I want bigger motor on my blaster but i dont know what to use or if there are even any engine swap kits fora blaster out there
Old Sep 30, 2003 | 06:47 PM
BLASTERDEVIL2's Avatar
An old yz490 bolt's right in.
Old Sep 30, 2003 | 07:34 PM
ikswodolg's Avatar
what years of the YZ, and how much mods have to be done to mounting brakets, and to run the exhuast?
Old Sep 30, 2003 | 08:32 PM
I think it's the 92-94 yz490. You can get a swingarm off an old tri-z shave a 1/16 off each side and bolt it right up. use the rear shock too.
Old Sep 30, 2003 | 11:17 PM
yfsrider's Avatar
that will rattle your teeth out. thats a major project you would be taking on. rubber shock absorbers would have to be on all mounting areas as well as pegs probably. a yz250 is the max i would go. you will have to weld some new mounts and stuff but it will be a better idea. also remember that you will have a large radiator to mount on the blaster with one of those engines and there isnt anywhere to put it. a very small space in front of the engine, but not much.
check this out, it will be very helpful
macdizzy blaster/dt200 engine swap
bzdok1234
30
Feb 23, 2016 01:55 PM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
toonces
Jul 28, 2015 01:58 PM
tweeder
Jul 5, 2015 01:57 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
