K&N vs. Uni Filter
Old Oct 3, 2003 | 08:55 PM
XxDumontRaptorxX's Avatar
Default K&N vs. Uni Filter
Originally posted by: JoshCVBz
Speaking strictly of performance, without getting into which is the better FILTER, I would have to say that you would not notice much of a difference.
I had a completely stock '01 Banshee with a stock (and extremely dirty) filter, and my neighbor had a Stock '01 Banshee with a K&N filter. Mine was faster....not sure why. We run the same gas/oil mix. My tires were 20" and his were 22" the first few times we raced...I was faster acceleration AND top end. I put on 22" tires a couple weeks later and the results were exactly the same.
-Josh
Well the banshee has no problems with getting air to the engine (stock) so a K&N wouldnt make a difference. The banshees stock pipes resctrict the flow of air out of the engine, so you can't really pull much more air in. (Without changing the pipes) When the pipes are changed, and you have more flow out of the engine then you need better flow into the engine (better filter) for power. I've heard K&N's do better than normal foam filters, in terms of performance. Wont be a noticable diference with low modded quad, but with alot of mods it may help quite a bit. This has just been from my experience and is not written in stone.
Old Oct 4, 2003 | 06:14 PM
Hiram's Avatar
I had a K&N on the Rappy before and I always wash and oil my filter before each time out, but I would notice fine powdered dust on the intake boots every time, here's an example of how bad the dust here that if someone is riding in front of you you wont see unless you stay back at least sixty feet and still after a couple of hours I get a bad nasal headache.
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
