Raptor frame bracing
Old Oct 20, 2003 | 11:08 PM
NY02Raptor's Avatar
Default Raptor frame bracing
guesset photos? anyone got some yet...
Old Oct 21, 2003 | 04:25 PM
440grl's Avatar
We are on our second rappy frame - first one started cracking, we welded it up, gusseted it, etc......next thing is cracks everywhere!!! By the time we got a new one we counted 20 places the first frame had cracked! And in one place the metal had actually blown out - like a flower!!! It was the wierded thing I have ever seen! This bike is raced VERY hard, however - and most of that use was with the stock shocks......we bought a new stocker (got it at cost) and with Custom Axis suspension, we figure it will hold together much longer. Just about any stock frame on any quad is going to crack if it's raced hard.......some just crack quicker than others.
Old Oct 28, 2003 | 04:05 PM
warrior86's Avatar
how bout them photos?
Old Jan 10, 2004 | 12:34 PM
UBETRUN's Avatar
Got mine all apart and ready to weld, anyone have some pics of Raptor frame gussets?
Old Jan 10, 2004 | 12:47 PM
  #15
FISHER1648's Avatar
I've been chasing cracks for the past year. So far I have repaired 4 actual cracks in various different areas. Numerous other areas have the paint chipped and "puckered" where it's going to develop a crack eventually. This is rampant on the upper rear shock mount area.
A new OEM frame is an option but it'll just crack too. The frame cracking, one-way, tranny (twice), and numerous other problems finally convinced me to look for a diffeent platform. I'll patch up the cracks as they come and hopefully un-a$$ this thing soon !?
Old Jan 11, 2004 | 10:45 AM
  #16
UBETRUN's Avatar
Fisher - Which part is cracking, is it the flat metal of the rear shock upper mount itself or the round cross bar that holds the upper mount? If it's the cross bar, is it cracking where it joins the vertical frame rails or in the center where the shock mount is attached? Thanks!
Old Jan 11, 2004 | 10:56 AM
  #17
FISHER1648's Avatar
So far the following areas have actually cracked and have been welded:
1) Lower right rear corner.
2) Upper Left main tube (about where your knees are)
3) Left lower subframe mount (on main frame)
4) Right Subframe Y (near coolant tank)
Areas that look like they are going to crack (puckered paint) are primarily on the welds that hold the upper rear shock mount to the main cross tube. Just about all of the joints are showing stress. Also, a couple spots where the tube meets the main frame are chipping.
Old Jan 11, 2004 | 12:01 PM
  #18
RaptorRidr660R's Avatar
If anyone needs a frame or subframe that is not cracked or bent at all PM me, I have both in blue from my 02!!!
Old Jan 11, 2004 | 03:45 PM
  #19
gRider's Avatar
punker660 i read youre posting and was wondering if you had fixed the mounts. the same thing happenend to me after i hit a tree and broke my left upper a-arm and now that i put new a-arms my whole left side sits about two inches back than the other side.
Old Jan 11, 2004 | 03:49 PM
  #20
Punker660's Avatar
I've never fixed the problem but the place I took it to said he could brace those spots easily. I'll try and get some pics up.
