would a warrior smoke a 300ex?
Originally posted by: JohnnySplat
that all depends on your definition of smoke. a +1t front will make a difference, but thats if the bike has the power to even pull itself up to the full potential, a full performance exhaust would give the power for the 300 to pull a bit ahead of the warrior, and if you gave it the +1t sprocket youd see quite a difference. but then again, is it really fair? a stock warrior expecting to beat a semi-modded 300ex? if you left them both stock or modded them equally, the warrior will always win.
Originally posted by: hondaracer305
I completely agree jed250. and yes a 300ex will lead a warrior off the line, but about midways down the strip, the warrior will slowly outrun a 300ex.
#17
i agree with the fact that a 300ex would fare better if it was a 350, but also, adding a tooth to the front sprocket would make it faster, ... if it had the power to pull it. the ex doesnt have a 14t front sprocket, probably because honda found out that it cant pull it, or that it takes so long to get there that it makes it a slow bike the rest of the time! if the engine doesnt have the juice to pull to the higher speed, it would really be pointless, youd gain a fraction of a mph on top end and your accel would suck. so, with you constantly trying to say "what if the ex this and well the warrior has this, so its not fair" why do you bother comparing the in the first place if youre not satisfied with the results? a stock warrior will beat a stock 300ex, plain and simple. besides, speed isnt everything.
#18
btw, i wasnt trying to be mean to zipzap, he got his answer and was satisfied, i was trying to get jed250 to understand, a warrior is faster than a 300ex, you can mod them, but thats not fair, so stock for stock the warrior is faster, it might not make you happy, but its the truth, so leave it alone.
