Taller Tires for Warrior
Old Jun 12, 2000 | 01:26 PM
GJ's Avatar
GJ
Has anyone put taller tires on a warrior, like 23" fronts and 25" rears. I would like to know what the effects on handling were? Were any gearing changes needed? Tire suggestions? Im trying to get some clearance in the rutted trails I ride but dont want to take a huge cut in the sport department. Thanks for any input. GJ
Old Jun 12, 2000 | 04:55 PM
PC_350_Warrior's Avatar
I dont have larger tires on, actually I have 20" inchers in the back. I would think you could get larger ones without a huge difference in handling. You might have more roll-over in the corners though. Honestly I havents seen larger than 22" rear tires except for utility quads. If you do get larger tires you might wanna get one tooth smaller countershaft sprocket to keep your bottom end torque.
Old Jun 12, 2000 | 09:19 PM
YWARRIOR350's Avatar
I HAD TALLER TIRES FOR MY WARRIOR AND I DIDNT LIKE THEM BUT HERES WHAT YOU NEED TO DO BUY YOU SOME 24=9=9 AND PUT LOW AIR PRESSURE IN THEM TOO WIDEN ALITTLE AND THEY WILL BE LIGHT WEIGHT AND HAVE MORE
HP AND MORE GROUND CLEARENCE
SCOTTY J. 87 WARRIOR W/ 42mm CARB FMF PIPES AND SILENCER SPLIT FIRE SPARK PLUG
Old Jun 12, 2000 | 10:51 PM
How are you going to get more HP out of a freakin tire!?!?!??! Didnt think so!
Old Jun 13, 2000 | 01:17 AM
GJ's Avatar
GJ
Who said anything about getting more HP out of changing tire sizes? All I am asking is if the larger tires will make it handle alot worse. Larger tires on any quad will take away from the motor some. Cant climb these rutted out hills and trails dragged bottom.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
black_thunder
Sep 20, 2015 10:21 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
