t-6 on a mod shee? Ordering pipes tonight!
I can't imagine this is true, but a dude at the local shop here says the t6's are life time guaranteed against rust and bluing...I know this ain't true...please confirm...[img]i/expressions/face-icon-small-mad.gif[/img]
Straight from Toomeys Website Look at very bottom.
Although we at Toomey Racing USA constantly strive to do our best work for each and every customer, in everything we do, we want you to be aware of a few realities regarding the chrome plating we have done to our pipes.
The plating is performed by an outside company and is not in the control of Toomey Racing. We select our vendors very carefully based on our quality tests and we inspect every pipe that goes to plating before and after the plating process to insure quality. When you receive your pipes, they have been double checked for quality.
However, you must understand that the plating process is not a perfect process. It is in the nature of any plating that there might be an occasional flake of the plating material. This is due to the two dis-similar expansion rates of the steel and the chromium. The process is an electro-bonding method which bonds the materials molecularly. If you have any flaking of the chrome,within the first 30 days, the plating company will warranty the plating independently of us at no charge. We will give you their name and number if you need this service. Just don't freak out, it happens.
Regarding bluing: All chrome plating will turn blue when exposed to sufficient heat. Anybody who tells you any different is crazy. It is inherent in the material. We have heard stories of some customers who have friends with another brand of pipes whose chrome never blues. I believe them. The difference here is temperature. We are the only pipe company that supplies you with the "Perfect Jetting Kit" that provides your Banshee with the exact carburation required by this combination. You can be assured of maximum performance because your Banshee will be jetted accurately, and therefore produce the optimum operating temperatures to make maximum horsepower (heat is power). The competing systems do not. Their temperatures are lower and therefore are not producing the best power, or heat, thus no bluing. That's why.
If you don't want them to blue, then run your bike richer. If you want to blow in enough raw fuel to extinguish the combustion temperatures enough to lower the power output so as to not blue the pipes you will have success. (Why would you buy the highest power racing pipes available if you don't want to use all the power? Why else do you ride a Banshee?) We believe the power is the primary goal and the relative beauty of the chrome is strictly secondary. Bluing is not covered under warranty.
Here is there actual Warranty statement
Toomey Racing USA, Inc. (Toomey) warrants only to the original purchaser the equipment purchased is free from defects in material and workmanship under normal use and service. Components of the equipment are supplied to Toomey by others and Toomey warrants such components to the purchaser only to the extent that such components are warranted to Toomey by the supplier. Toomey's obligation under this warranty shall be limited to the repair or exchange of any part or parts which may thus prove defective under normal use and service within one year from date of the invoice and which Toomey's examination shall disclose to Toomey's satisfaction to be thus defective. This warranty is expressly in lieu of all other warranties expressed or implied and of all other obligations or liabilities on our part, and Toomey neither assumes, nor authorizes any other person to assume for Toomey any other liability in connection with the sale of this equipment or any part thereof which has been subject to accident, negligence, alteration, abuse, or misuse. Toomey makes no warranty whatsoever in respect to accessories or parts not supplied by Toomey. The term "original purchaser", as used in this warranty, shall be deemed to mean that person for whom the equipment is originally invoiced. This warrant shall apply only within the boundaries of the continental United States.
The remedy defined in this statement shall be the Purchaser's exclusive remedy against Toomey Racing USA. In no case shall Toomey Racing USA be liable hereunder for any consequential damages.
THERE ARE NO WARRANTIES, EXPRESS OR IMPLIED, INCLUDING ANY WARRANTY OF MERCHANTABILITY, WHICH EXTEND BEYOND THE FACE OF THIS STATEMENT.
#16
Originally posted by: TexasPsycho
bigscary where do you work. we're not to far from each other. i'm in carthage used to be centers rivel town. where do you ride ?
I usually just ride dirt roads and such.........
mrtidy
Feb 3, 2016 05:00 PM
greg86hd
Sep 16, 2015 12:32 AM
