My Raptor finally fires with EFI system!!!!
#15
#16
#17
#18
There are a couple of ways the EFI may pick up more HP versus the stock carbs. One way in which I might see improvements with the EFI is if I was starving the engine for air through the stock carbs in which the larger EFI throttle body would flow better and pick up more peak hp. The other way EFI might make more HP than a carb setup would be if the carbs just weren't tuned properly and the additional or more accurate fuel control of EFI would dial in the bike better. My motivation for doing the EFI was not for any of the above reasons. The EFI will provide the fuel and ignition control that is critical when going to forced induction. The foundation is set!!
#19
