Master Builders
If you are going to use a HotCams cam you don't need to do the larger center intake. Take a look at the cam cards that they have listed on-line. The cam already does the same thing (with more lift & duration). If you are using any of the other cams then the larger center intake will help balance the flow.
Stirling
Aug 9, 2015 01:49 PM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
