13-1 686 with 39 mm FCR's man-o-man
#33
$1250. . . Ouch!
The blank FCR's for the DS are about $625-$675 through a Sudco Dealer (I think $675 directly from Sudco.) - You'ld have to get the part number to be sure to get the correct spacing between the carbs.
You would need a carb to head adapter - I assume the stock boot wouldn't work???
You'ld also need the air filter adapters (I think they are about $35 each) + air filters (Uni's are about $15 each + pre-filters - Outerwares - $20 each.) - this set-up is without an air box.
You'll also probably need a new throttle cable and possibly a twist throttle ($100???)
14, what are you guys doing with the intake (carb to head adapter)? That must be where all the price is??? Wow, that is like $350 to $400???
Does that $1250 include everything above?
#37
Originally posted by: LOWBOWTIE
I have an Idea the bottom just fell out of the 35mm.[img]i/expressions/face-icon-small-shocked.gif[/img] How much $?
#38
Just got off the phone with Bob Craycraft. He wants to do a little more fine tuning before he sell the whole kit so I have to keep my 35mm for a few more weeks. Sounds like the 39mm carbs and intake are putting a whole bunch more air into the motor, sweet!!
#39
Bob has been on a role lately. Between the carbs, the new clutch, and all the builds I wonder if he ever gets to eat or sleep???[img]i/expressions/face-icon-small-confused.gif[/img][img]i/expressions/face-icon-small-tongue.gif[/img]
LMAO @ sixsixT!!!
LMAO @ sixsixT!!!
#40
Dune Me- you are partly correct. I am not looking at the prices but the 39's start out like you say. Then they add another 75 dollars to bolt them together for the raptor. Then add the adapter flanges, the dual K&N's with outerwares (about a 100 bucks) and the intake is about 250 dollars. Bob Craycraft may make 75 dollars for his trouble
