Warrior Hickup
Old Nov 17, 2003 | 10:26 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
Default Warrior Hickup
well sometimes at a low idle when it missfires.. it'll just shutoff
Old Nov 17, 2003 | 10:37 AM
shastadog's Avatar
Tell it to hold it's breath and take ten sips of water[img]i/expressions/face-icon-small-wink.gif[/img] Just kidding pal. My Wolvy seems to do the same think... worse when its cold...I know the cause of mine is not the slide plunger or the other plunger-(choke??) both of them have been replaced lately. I agree with it probably being the float set a little bit off. Let us know what you find.
Old Nov 17, 2003 | 11:17 AM
warriorgod's Avatar
I'm not so sure that its the float heigt because when i lean out the mixture screw and it makes it even worse. So i think it's to lean.
Old Nov 17, 2003 | 11:28 AM
95wolv's Avatar
A too low float level can cause the idle circuit to not pull enough fuel, and a little air sucked in could lean out the mixture just enough to kill the motor, that could be why leaning the mixture out made it worse. I guess I'll know more after I pull my carb apart and check it out.
Old Nov 17, 2003 | 11:38 AM
  #15
warriorgod's Avatar
On my warrior, i dought that its not getting enough air because i have a K&N airfilter and the air box lid off.
Old Nov 17, 2003 | 11:39 AM
  #16
warriorgod's Avatar
Which i just cleaned it
Old Nov 17, 2003 | 12:00 PM
  #17
shastadog's Avatar
95Wolv did ya ever find those factory flaps? I may have a lead on another set of used ones...no luck on new old stock at the local dealer. PM me if your interested.
Old Nov 24, 2003 | 07:39 PM
  #18
warriorgod's Avatar
I think I figured out hats wrong on mine and maybe yours is the same thing, all i did was clean the 3 little wholes in front of the round valve. what happened was the engine wasn't getting enough fuel because those pilet holes were pluged. WELL, thanks for the help.
Old Nov 24, 2003 | 08:05 PM
  #19
KILLERCUDA's Avatar
I heard those hickups with peanut butter [img]i/expressions/face-icon-small-wink.gif[/img]
Old Nov 24, 2003 | 08:14 PM
  #20
lt230racer's Avatar
hey killercuda where do u live in racine
