Swingarm Question
Old Nov 19, 2003 | 02:19 PM
Guest
Guest
Posts: n/a
Default Swingarm Question
How many of you guys with +4 inch swing arms just run an heavier spring on the rear shock without re-valving the shock? Is this possible or even recommended? I know allot of guys tell me that The rear shock needs to be re-valved for an extended swing arm period. I don’t do allot of jumping, although I will launch off some razor backs here and there, sometimes by accident [img]i/expressions/face-icon-small-blush.gif[/img]..
thanks
Old Nov 19, 2003 | 03:45 PM
DuneMe's Avatar
I put a +4 swingarm on my Wife's Raptor. I just adjusted the stiffness a bit. With her weight 125 lbs. I don't plan on re-valving or anything right now. I'll probably get her a set of new front shocks next year and when I do I'll go ahead and have the rear-shock done.
I think Works will re-do it for a fairly reasonable price.
Old Nov 19, 2003 | 03:55 PM
raptor03's Avatar
yea works will do it but i just stiffened up my spring and it's fine when i was jumping at Glamis ,so no need for the revalving right now..
Old Nov 19, 2003 | 04:02 PM
Guest
Guest
Posts: n/a
Raptor03>> did you add an Eibach spring to the shock to stiffen it up, if so how much was it? and about how much do you weigh.. I'm in the 165-175lbs range. I think i'll just do what u did.
Old Nov 19, 2003 | 04:29 PM
RoostItUp's Avatar
Had my +4 on there for a year now and didn't change anything with the shock, it works great! I didn't even notice a change in the suspension after I got it on. You should be fine.
Old Nov 19, 2003 | 05:06 PM
Guest
Guest
Posts: n/a
right on...i'll try it.
Old Nov 19, 2003 | 05:36 PM
raptor03's Avatar
just messed with the preload i believe,got a flat head scre driver and gave a turn or two,and i weigh about 200 lbz...you will be fine..
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
