Holy Piston
Old Dec 22, 2003 | 10:46 PM
  #41
Yamaha660R's Avatar
Default Holy Piston
With all this JE talk....maybe Wiseco pistons are the way to go????
Old Dec 23, 2003 | 12:25 AM
  #42
BigScary's Avatar
Default Holy Piston
Originally posted by: Dynoray
I would have to agree with Gary, we run JE 102mm at 12.6:1 on pump gas. I have had Wiseco piston's (our 324gram design stock car pistons) crack along the valve relief, a larger radius fixed the problem, but have never had a problem with JE.
How much timing was being run with this piston? Here is a video of one that went together in the spring and has been pounded since (12.6:1)
RayRaptor
at what elevation were you running pump gas in 12.6:1?
Old Dec 23, 2003 | 08:44 AM
  #43
Dynoray's Avatar
Default Holy Piston
100-2000ft
Ray
  #44
Dynoray's Avatar
Default Holy Piston
A stk YZF is 11.9:1
Ray
Old Dec 23, 2003 | 08:52 AM
  #45
garyc660R's Avatar
Default Holy Piston
Unfortunately an unbiased opinion will not be in the answer no-matter who the piston representative is IMO. Hopefully he will use the true info if the piston is in fact a defect. There is a lot of carnage that goes along with admitting failure on the manufacturers part. JE makes a lot of the pistons for top fuel dragsters making in excess of 500+ hp per hole.
Old Dec 23, 2003 | 08:56 AM
  #46
garyc660R's Avatar
Default Holy Piston
By the way, those dragsters use a flat top piston and get their power the best way....through the head. A "pop up", high compression piston promotes detonation....or anything that alters flame travel for that matter.
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
