ok i picked fmf, now whats to doing jetting
Old Jun 20, 2000 | 08:30 PM
NWscramrider's Avatar
i picked fmf fatty pipes and should get them by the end of the week. so,,, my question is how hard is the jetting to get it right???? i live and ride around the 500- 1000' level. i also bought the two separate k&n filters with outerwears, so i imagine that will make a difference with the airflow. all of your experience and suggestions are appreciated thanks..........Erik
Old Jun 20, 2000 | 08:35 PM
Y2K300EX's Avatar
What kind of quad is it?????
Old Jun 20, 2000 | 09:23 PM
stevie's Avatar
Probabley a banshee with the twin air filters
Old Jun 21, 2000 | 02:30 AM
yes it is a banshee sorry
Old Jun 21, 2000 | 11:00 AM
garyc400ex's Avatar
THE PIPES SHOULD COME WITH SOME RECOMMENDATIONS FOR VARIOUS RIDING CONDITIONS AND ELEVATIONS. GOOD CHOICE!
Old Jun 21, 2000 | 11:38 AM
RoostKing's Avatar
My FMF's came with 260's for the mains, which at almost 6000 feet altitude was too much, but with 240's it runs good. At your altitude, with no airbox, I suspect you may need higher than the 260's. Just try them and check the plugs. If you dont know how to check the plugs, do this. Get everything buttoned upo run it until its warm, then just haul butt wide open throttle through 5th gear, pull in the clutch, and kill the motor, Coast to a stop and check the plugs. If they are the color of cardboard, your lookin pretty good.
Good Choice on the pipes, you wont be dissappointed!
Good Luck,
RoostKing...
Old Jun 21, 2000 | 12:49 PM
DunePilot858's Avatar
I have pretty much the same setup as you. I ride around sea level and up as high as 1000 feet with out changing jetting. I have 30 pilot jets new needles and 300 mains. I don't have clamp on filters but I don't run an airbox lid with my K&N pro design adapter.
Old Jun 24, 2000 | 12:41 AM
MotoMatt's Avatar
Do not use the 260 mains as supplied with your pipes. These will only be effective with your air box still intact. I would start with a 280-290 main and a 32.5 pilot and go from there. I am assuming your banshee has stock size ports.
Matt Sheldon (Magic Racing Sales Manager)
mywifesquad
8
Sep 21, 2015 08:20 AM
Bonzhonda300ex
Sep 17, 2015 10:44 AM
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
Brandon400
Sep 7, 2015 12:20 PM
Brandon400
Sep 5, 2015 08:44 PM
