3000$ on hand for raptor motor modifications, suggestions?
Appreciate sixsixt for this suggestion, sounds like what Im looking for:
105mm 10:1 piston 175 to 200
Sleeve cyl. 100 to 150
machine case 65
3 intake valves 1mm oversize 150
Ti valve springs 150
Port & polish 400
Carillo rod, installed and crank balanced 400
GYT-R clutch 100
Cam 135
Gaskets, oil, filters 75
WHat do you all think?
machine case 65
Port & polish 400
GYT-R clutch 100
Cam 135
kyraptor- your list looks good. You will not be able to buy FCR's on that budget. But i would think you would be able to find some used 35mm FCR's for around 500 that you can add later.
I could make friends with someone that had 35mm FCR's collecting dust [img]i/expressions/face-icon-small-wink.gif[/img] [img]i/expressions/face-icon-small-wink.gif[/img]
What do you guys think? Those should be enough for the Wife's mild 686 huh? Do you think the 39's would add anything more to her setup?
Kyraptor: Get the carbs!!! Also, leave yourself some for an extended swing-arm!
